12 years agoHow to setup the Quartus 13,1 in Ubuntu 12.4.1?
I am new about the Quartus in Linux (also new in Linux). I just install Quartus 13.1 in my Ubuntu. Then I can only start Quartus in the folder I installed. How should I do setup that I can start Quar...
12 years ago --- Quote Start --- Thanks very much for reply. It works. So for: QUARTUS_64BIT=1 export QUARTUS_64BIT It sets I want to use 64 bit instead of 32 bit. How do you know this variable (QUARTUS_64BIT) ? Where should I check it? Thanks in advance. --- Quote End --- I'm not quite sure I understand your question. If you set the QUARTUS_64BIT environment variable as shown above Quartus will start in 64-bit mode. You don't have to check it. If you don't want to run the 64-bit version of Quartus simply don't set it.
