12 years agoHow to setup the Quartus 13,1 in Ubuntu 12.4.1?
I am new about the Quartus in Linux (also new in Linux). I just install Quartus 13.1 in my Ubuntu. Then I can only start Quartus in the folder I installed. How should I do setup that I can start Quar...
12 years ago --- Quote Start --- If you just want to run quartus and modelsim you can add this to your .bash_profile (or I think that would be .bashrc on Ubuntu since they seem to do everything from the .bashrc file):
qhome=/path/where/you/installed/quartus
PATH=$qhome/quartus/bin:$PATH
PATH=$qhome/modelsim_ase/bin:$PATH
export PATH
QUARTUS_64BIT=1
export QUARTUS_64BIT
Assuming you have installed and want to use the 64-bit version as well. You must source the .bash_profile/.bashrc file or start a new shell for it to take effect. --- Quote End --- Thanks very much for reply. It works. So for: QUARTUS_64BIT=1 export QUARTUS_64BIT It sets I want to use 64 bit instead of 32 bit. How do you know this variable (QUARTUS_64BIT) ? Where should I check it? Thanks in advance.
