12 years agoHow to setup the Quartus 13,1 in Ubuntu 12.4.1?
I am new about the Quartus in Linux (also new in Linux). I just install Quartus 13.1 in my Ubuntu. Then I can only start Quartus in the folder I installed. How should I do setup that I can start Quar...
12 years agoIf you just want to run quartus and modelsim you can add this to your .bash_profile (or I think that would be .bashrc on Ubuntu since they seem to do everything from the .bashrc file):
qhome=/path/where/you/installed/quartus
PATH=$qhome/quartus/bin:$PATH
PATH=$qhome/modelsim_ase/bin:$PATH
export PATH
QUARTUS_64BIT=1
export QUARTUS_64BIT
Assuming you have installed and want to use the 64-bit version as well. You must source the .bash_profile/.bashrc file or start a new shell for it to take effect.
