Benjamin182
5 years agoHow to setup constraint for a PWM DDR output
I've got a design with a master 100-MHz clock. We need a PWM with a 5-ns resolution. One solution that I've come up with is to use a DDR output block to decrease the resolution from 10 ns to 5...
SyafieqS
5 years agoWe do not receive any response from you to the previous reply that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
