ZhiqiangLiang
1 year agohow to set those parameters of clock crossing bridge?
Hi, My FPGA model is Cyclone 10 LP 10CL120YF484. on Platform Designer, NIOS frequency is 80MHz, and my IP is 160MHz. In NIOS C code, I would like to read/write registers of my IP. In my design, ...
- 1 year ago
I reviewed some diagrams on the website, and based on what I saw, option 2 is actually the correct setup. The diagrams clearly indicate that option 2 is the proper way to connect.
KennyT_altera
1 year agoThat is correct, I think In Platform Designer, connections are typically restricted to slave-to-master and master-to-slave configurations, rather than allowing master-to-master connections.
