D22
7 years agoHow to set path skew through SDC?
Hi! I'm trying to develop a sort of TDC (Time-to-Digital Converter) using the carry-chain in a Cyclone device. In particular, I’m focusing on the fine measurement that, for my application, could hav...
sstrell
7 years agoI'm assuming (or presuming) that these paths have registers on both ends. What speed are you running both sides at and you have constrained the clocks correctly? Have you tried seeing what results you get when you don't use Logic Lock? Remember that LL is basically another constraint on the Fitter, which could prevent it from choosing optimal placement and routing.
