13 years ago --- Quote Start --- That is correct. TCL = Tool Command Language Its a language for controlling (scripting) tools. You write your code in VHDL, you write timing constraints in Tcl (in an .sdc) file, you can manage the Quartus and Modelsim project build sequence using Tcl, and you can post-process timing analysis results using Tcl. Cheers, Dave --- Quote End --- Thanks very much, Dave!
