13 years agoHi,
you can read the build in help in quartus 1) by File menu > New... > Design Files > Tcl script or you can use a text editor 2) To run your script, go to View menu > Utility windows > Tcl concole... then type source your_script.tcl if your_script.tcl is in the project directory (there are other command line... with "quartus_sh" for example) At doulos.com, there are also few well explained examples.
