8 years agoHow to run counter program in modelsim?
I am running following counter program without test bench. But in modelsim, i am not getting any signals. Please anyone share me counter examples program rar. I want to run counter program eit...
8 years agoHi,
You can check the files attached for reference. For simulation using Modelsim steps below is one of the way, 1.Files->Change directory->Browser to the folder where you have the test bench or top design file and click Ok. 2.File ->new->library->with default option click ok. 3.compile->compile->select the file (test bench & design top file)->compile->done 4.Simulate->start simulation->select the library work"+"->select the top file under the library ->click ok. 5.objects->right click and add the wave to the design 6.Select run length and run. In qsys custom component refer links https://www.youtube.com/watch?v=v6rhbvablo8 https://www.altera.com/en_us/pdfs/literature/hb/qts/qsys_components.pdf Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
