Prachi_S_Intel
7 years agoHow to resolve a libpng12.so.0 error on CentOS System?
When I am trying to install Intel FPGA SDK for OpenCL, I am getting an error as "quartus: error while loading shared libraries: libpng12.so.0: cannot open shared object file: No such file or director...
HRZ
7 years agoDo you get this error while installing the SDK or using it? If this is during installation, can you post the command you run that generates the error? If this is during usage, can you post the environmental variables that you have set in your .bashrc to get OpenCL to work? You can install that missing library by running "sudo yum install libpng12". However, this should not be normally required unless you are using an old version of Quartus. Please also post the version of Quartus you are using and your board model.
