ldm_as
6 years agoHow to report STA (Timing Analysis) just post-Synthesis but before P&R (Placement and Route)?
Hi All, How to report STA (Timing Analysis) just post-Synthesis but before P&R (Placement and Route)? Is it possible to generate the STA report (e.g. setup violations) just after the Analysis and S...
KennyT_altera
6 years agoNope, you can refer to https://www.intel.com/content/www/us/en/programmable/support/support-resources/design-examples/design-software/tcl/auto_processing.html
It is actually the same like the example above by not using GUI. Any reason that you need to use gui to automate the process? Usually, the solution is not using GUI for scripting purposes.
