ldm_as
6 years agoHow to report STA (Timing Analysis) just post-Synthesis but before P&R (Placement and Route)?
Hi All, How to report STA (Timing Analysis) just post-Synthesis but before P&R (Placement and Route)? Is it possible to generate the STA report (e.g. setup violations) just after the Analysis and S...
sstrell
6 years agoIf you are using the Standard edition of Quartus, you can select to create the timing netlist in the Timing Analyzer based on the post-map netlist (Create Timing Netlist command). If you are using the Pro edition, you have to at least compile to the Plan (or Early Plan) snapshot, which is after synthesis but before the main stages of Place and Route. You can create the timing netlist based off the Plan or Early Plan snapshots.
#iwork4intel
