swm
4 years agoHow to reliabily program multiple FPGAs using quartus_pgm?
I have a server with 8 x Stratix 10 SX boards (Terasic DE10Pro), which I would like to be able to program over usb-to-jtag. When I have one or two baords installed, I can reliably program a board, e...
FvM
4 years agoThere's a general problem when working with multiple programmers connected to one PC (= one JTAG server). Establishing the connection to a programmer can fail if another programmer is active at that time. Connecting all programmers first and than starting activities should work.
This might be a problem with the intended command line operation but it works in GUI operation of multiple programmer or debug tool instances.
swm
4 years agoThanks for confirming that you have also seen difficulties with multiple programmers connected to one PC.
I did try the GUI for programming, but this didn't improve programming reliability; I see the same behaviour. I am only programming one FPGA at a time to avoid any issues with jtagd struggling with parallel clients.
