How to reduce re-compilation time in Quartus pro ?
There are many techniques to save compile time. Obviously, use a "beefy" machine for compilations (multiple cores, lots of RAM) and make sure the parallel compilation feature is enabled in Quartus.
Getting to design-specific ways of reducing compile time, block-based design techniques can potentially reduce compile time:
And that includes the new fast preservation feature:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an899.pdf
Also search for "rapid recompile".
There are training classes available for these as well:
Reducing Compile Time with Fast Preservation
Incremental Block-Based Compilation in the Intel Quartus® Prime Pro Software: Introduction
Finally, you can use Fitter snapshots to compile up to a particular stage of the Fitter to save time (referred to as incremental optimization), but if you need to test this in hardware, that won't be as useful:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-compiler.pdf
