APras18
7 years agoHow to package a custom IP containing IP as submodule
Hi, I have created simple design where I instantiate LPM_sub_add IP as submodule. I would like to package the whole top level so that I can reuse IP. Below are the steps used: Create a new compone...
APras18
6 years agoI am still stuck at this point. The design i am trying to port has native phy, generic fifo which are not available as part of the platform designer. Even though I am using all Intel IPs I am unable to migrate the design to platfrom designer. Its really annoying. As you told that "But if you make the generation of the IP, you should see one of the files have the defparam for you to be used.", can you tell me the exact file name and the location where it can be found?
