APras18
7 years agoHow to package a custom IP containing IP as submodule
Hi, I have created simple design where I instantiate LPM_sub_add IP as submodule. I would like to package the whole top level so that I can reuse IP. Below are the steps used: Create a new compone...
KennyT_altera
6 years agoDid you follow the steps that I provided u in the mail? Basically, when you generate the IP. Under the *.qip, it had somethings like .v files that consist of the defparam parameter for you to used.
Unfortunately, we don't have documentation for the specific Ip that you want. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_low_level.pdf?wapkw=Designing%20with%20Low-Level%20Primitives
But if you make the generation of the IP, you should see one of the files have the defparam for you to be used.
