8 years agoHow to make communication between computer and Quartus using Python?
Hi, I am very new to this tool Altera Quartus, but i need to build the design that i need to give command from the coumputer to PC through Python. So, my question is how to build the design...
8 years ago --- Quote Start --- Hi, If you have the Quartus executable file in your PATH, you can simply do the command : os.system('quartus_sh --flow compile <quartus_project_name>.qpf') You must generate your project with quartus UI a first time to have the <quartus_project_name>.qpf file. Regards, Jerome --- Quote End --- I don`t have any file. Just i am going to build the design with Ethernet concept. MY design flow as follows 1. Going to give command from computer through Python 2. Quartus should receive that command and should generate the signal (using Cyclone V FPGA). How to build in Quartus ? Whether i need to use Qsys or NIOS Processor ? Please explain me with steps. :(
