dsun01's avatar
dsun01
4 years ago
how to know the Eclipse compiled hex file match the source code?
Dear Intel Support/Expert,
I am working on an old project which need to do a lot of upgrade, FPGA chip and Quartus tools. after I port the old Nios II project to the new FPGA, it won't work. I tried to comment all code out, except one line printf("Hello from Nios II!\n"); it won't show the text on the simulation console. I made a comparison with AN351 result. I found something wrong but don't know why.
for AN351 which is working in my simulation environment.
the C source code is
#include <stdio.h>
int main()
return 0;
after compile I checked the .hex file. I show a small piece of the text, I can find 6c6c65486266206f. which is the ASCII code of "Hello fr", of cause I can see it in the modelsim memory list when execute simulation.
:20158000E0BFFE17E0BFFF15E0BFFF1710000226002AF07000000106002AF0B00001883AD9
:20158800003FFF066C6C65487266206F4E206D6F20736F69002149490000000A7665642F33
:201590006C756E2F0000006C7665642F61746A2F61755F67000074727665642F61746A2F17
:2015980061755F6700007472000000000000000000000000000000000000000000000000B1
:2015A00000000000000000000000000000000000000000000000000000000000000000002B
But for the real application project. after I commented all the code, and only keep one line
printf("Hello from Nios II!\n"); after I compiled the project, I couldn't find 6c6c65486266206f in the .hex file.
I saw every time I change code, after "build all" and execute "run as nios II modelsim", the .hex file got updated, and the memory list file in the modelsim also changed.
how to make sure the compiled file match the source code in the project?
is there some trick to check the .hex file was compiled from the source instead of from somewhere else?
Beside the content of the printf, is there other C code that can be identified in the .hex file?
I am a FPGA designer, not good at Nios II and Eclipse tools. so I need an example like AN351 to make apple to apple comparison. It will be much helpful to get suggestions from experienced Nios II and FPGA system level engineers.
David
    • dsun01's avatar
      dsun01
      Thank you for reply.
  • EricMunYew_C_Intel's avatar
    EricMunYew_C_Intel
