How to Instantiate PLL and Reset without using QSYS or Platform designer
Thanks, I have Prime Lite and when I click on IPCatalog it does nothing?
There should be a list of all the IP you can add to your design. If not, you may have a bad installation of the software.
- JSLY4 years ago
I am using a max 10 fpag, with external pin DEV_CLRn is disabled in prime tool and there is no external pullup or pulldown, so how do I attach to the DEV_CLRn signal, is this signal internally generated inside the device, or will it get synthesized out because the tool setting has the pin disabled on the Max10->Device->Device and Pin Options->General-> unchecked "Enable device - wide reset (DEV_CLRn) is unchecked. how does the device come out of reset, do i still have an internal device_reset signal generated by an internal RC type circuit? IF so how do I instantiate or connect to that signal???
- sstrell4 years ago
Articles on what DEV_CLRn does:
https://www.intel.com/content/www/us/en/support/programmable/articles/000077167.html?wapkw=dev_clrn
Your design itself should have some type of reset control.
