DBay
8 years agoHow to import Logiclock regions with partition into upper level project using Pro
I can export a qdb partition file from a lower level project and import it into an upper level project as a design partition. This works fine. How do I import the LogicLock regions along with all the...
KennyT_altera
8 years agoDo you mean import LL region to another project? in Q18.1pro, there are only import design qdb files. There are no import LL region option available. If you want to have the same logic location. Just put design partition as post fit.
