NuvKFC
Contributor
4 years agoHow to import assignment files by command?
I already have a CSV file for assignment. Does there exist a command to import the CSV file into my projects? Could you please tell me? Thank you very much.
SyafieqS
4 years agoHi KfC,
You can import it via import assignment dialog box in Quartus menu. To do this, click Assignments | Import Assignments... click on the button labelled "..." and select the file.csv file. Click OK and then click OK again to import the assignments.
NuvKFC
Contributor
4 years agoHi SyafieqS_Intel
Thank you, SyafieqS_Intel, very much. Unfortunately, the same design has different pin assignment in each Quartus project for different verification engineers because the same pin has different functions. Could I use some command to add the file.csv in qsf file or in qip file? So, I can directly identify which assignment file is using.
