How to implement a module for accessing single block of on-chip memory in systemverilog?
Sorry about that if I didn't clearly state the issue here. The real problem is : I cannot instantiate two modules for accessing single block of memory.
Let say I have a single port ram module:
module single_port_ram
input [15:0] data,
input [7:0] addr,
input we, clk,
output [15:0] q
// Declare the RAM variable
reg [15:0] ram[63:0];
// Variable to hold the registered read address
reg [7:0] addr_reg;
always @ (posedge clk)
begin
// Write
if (we)
ram[addr] <= data;
addr_reg <= addr;
end
// Continuous assignment implies read returns NEW data.
// This is the natural behavior of the TriMatrix memory
// blocks in Single Port mode.
assign q = ram[addr_reg];
endmoduleI have a top module which connect to two single_port_ram modules for reading 16 bits data at addr1 and addr2 respectively.
logic[15:0] data1, data2;
logic[7:0] addr1, addr2;
logic[15:0] out1, out2;
single_port_ram ram1 (
data(data1),
addr(addr1),
we(0),
clk(clk),
q(out1)
single_port_ram ram2 (
data(data2),
addr(addr2),
we(0),
clk(clk),
q(out2)
);You can see ram1 and ram2 are actually TWO separated ram blocks (which is not my intent) as I declare the single_port_ram module twice.
What I want to do is : to have a single module (probably with port interface?) for accessing SINGLE block of memory so that I can create multiple instances of this module in different top modules for accessing same block of memory.
A stackoverflow user had the same issue and someone suggest to create port interface.
Since I am new to systemverilog, I am looking for a real example which can illustrate how it works.
Ken
