MoZdk
5 years agoHow to ignore simulation only ports when mapping to FPGA pins?
A design has a number of simulation ports that should not be tied to FPGA pins.
A VHDL example is shown in the source below, where the sim_only_* ports are for simulation only, thus should not be ...
- 5 years ago
Use Virtual Pin assignments in the Assignment Editor. That way the logic for the pins will still be implemented but they won't get connected to physical I/O.
sstrell
5 years agoUse Virtual Pin assignments in the Assignment Editor. That way the logic for the pins will still be implemented but they won't get connected to physical I/O.
