WKapp
7 years agoHow to I feed a single input clock pin to 2 PLLs
Hello, I am working on a design using Arria 10 GX. I included a DDR4 EMIF IP that wants a reference clock for its PLL(s). This reference clock is placed on a clock input pin. I also need to genera...
SreekumarR_G_Intel
7 years agoHello ,
As of my understanding it is not the tool issue . Actually tool is trying to help to achieve performance of the PLL within the jitter /Skew specified.
You can also notice Startix II and Arria 10 are not same architecture.
Few questions :
Did you try to use ALTCLKCTRL IP before connect to input of the other PLL reference clock?
Can I also know PLL bank that you are trying to use?
How do you check there is not input to EMIF PLL when you connect the other PLL to same clock ? is that using signal tap ?
Thank you ,
Sree
