13 years ago --- Quote Start --- One more observation. You are using pll input as sys-clk. I winder if you got any warnings. Moreover I don't see why you use negedge. --- Quote End --- Yes, I got several Warning but not Critical warnings as following: Warning (332009): The launch and latch times for the relationship between source clock: pll1|altpll_component|auto_generated|pll1|clk[0] and destination clock: pll1|altpll_component|auto_generated|pll1|clk[1] are outside of the legal time range. The relationship difference is correct, however the launch time is set to 0. Warning (15064): PLL "PLL_6us_3us_300ns:pll1|altpll:altpll_component|PLL_6us_3us_300ns_altpll2:auto_generated|pll1" output port clk[2] feeds output pin "clk_300ns~output" via non-dedicated routing -- jitter performance depends on switching rate of other design elements. Use PLL dedicated clock outputs to ensure jitter performance Warning (332060): Node: CK_Scan was determined to be a clock but was found without an associated clock assignment. I don't understand these warnings very well. For negedge I used, the reason is I think: "clk" is input to PLL and "clk_300ns" is output. Their positive edge is aliged in each 600ns (40*15, 300*2), so if I used posedge, whether will it cause racing and adventure? Thanks very much.
