13 years ago --- Quote Start --- use ck enable i.e. assign to your signal clk scan on the dge of sys_clk then use if statement for clk enable at the rate you want --- Quote End --- Thanks, Kaz. But I didn't understand what you suggested very well. Could you explain it a little more? I should mentioned a thing is "CK_Scan", this gating clock signal is for a chip output the FPGA, actually it is a output clock signal. And that chip needs the clock signal oscillates in the specific duration (counterScan>14 && counterScan<31 or counterSystemReset>300 && counterSystemReset<321) Andbesides the gating clock, do you have any idea about the hold time violated I showed? That is the thing I care most. Thanks very much.
