Altera_ForumHonored Contributor13 years agoHow to get the default modelsim.ini file back? I compiled the libraries of FPGA and get a new modelsim.ini file in complied directory. Then I directly copy this file into modelsim installation directory. The default one has been replaced. Then I ...Show More
Recent DiscussionsInterfacing Avalon Streaming FIFO IP with GTS Ethernet Hard IPInvalid license key (inconsistent authentication code)Regarding the issue of UFM not startingram retimingReset Release IP for Agilex needs Stratix 10 device files installed!
