10 years agoHow to generate Global RESET signal in Verilog?
Hi, I want to generate a active LOW global reset signal once FPGA device power up. I write my code like this: reg [9:0] reset_sync_n = 1'b0; //initialize the reset signal al...
9 years ago"specify certain values on start" doesn't guarantee a predictable design state after the first clock edge, because the power-on-reset is released asynchronously and might cause timing violations. At worst case, a state machine might fall into a not-recoverable illegal state or a counter start at an unexpected arbitrary value.
That's why you want a system wide reset that is synchronously released after the design clock is stable.
