15 years agoYou need to add this to your .qsf file for timing-driven fitting:
set_global_assignment -name ROUTER_TIMING_OPTIMIZATION_LEVEL NORMAL Also, if you want synthesis to be timing-driven, add this also: set_global_assignment -name SYNTH_TIMING_DRIVEN_SYNTHESIS ON There are check boxes for both of these settings in the Settings dialog box.
