Altera_ForumHonored Contributor13 years agoHow to enable pull-up of IOs? Hi, I want to enable the weak pull-ups of the I/Os. Is it possible to enable those using verilog code itself? Is it possible to enable the weak pull-up via programmable control bit from design? ...Show More
Altera_ForumHonored Contributor13 years agoPin features like current strength or pull-up enable can be only set at compile time.
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
