how to "duplicate nodes" and "reduce levels of combinational logic" to remove negative slack in timing analysis Quartus??
Those solutions are not typically what you would need to do to solve timing issues in an EMIF IP, only if the timing issues extended into the internal logic of your design. Are you using the hard or soft IP? Go back into the IP Parameter editor and double-check all your settings and timing values. Since you say you are using a dev kit, you should try using the example EMIF design that should be included with the download for the kit. The IP settings in the included design would already be set up correctly for that particular kit.
#iwork4intel
- SPraj46 years ago
Thank you .
I am using hard IP. Is that makes difference in parameter setting ??
And I have already checked IP parameters but will check again.
- SPraj46 years ago
As you suggested I tried to find example design for ddr3 and used the IP parameters in my design . I facing following errors (earlier there was no errors):
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 3 errors, 9 warnings
Error: Peak virtual memory: 771 megabytes
Error: Processing ended: Wed Nov 06 17:23:57 2019
Error: Elapsed time: 00:02:29
Error: Total CPU time (on all processors): 00:03:45
The only thing I have changed is ddr3 IP parameters. Please suggest possible solution for it.
Below is Qsys system I have created(and same has been attached):
