14 years agohow to dump routing elements in Quartus II
Is there a way in Quartus II to dump out the routing resources of a device using TCL? I am interested in STRATIX V. I know how to dump out routing resources of a used design using routing_pat...
13 years agoHello,
This command: quartus_cdb --64bit <qpf_name> -c <qsf_name> --back_annotate=routing Will produce <qsf_name>.rcf , which contains design routing. It'll also add low-level placement to your <qsf_name>. So back it up before running this command. @Rysc I disagree that it's only for academic purposes. I actually use placement and routing information to improve performance of my designs. Thanks, Evgeni
