14 years ago --- Quote Start --- But how can I check how much clock routing resources I have used for the design in my FPGA chip? --- Quote End --- You don't. Quartus will tell you if it runs out. I'm sure there is a report file somewhere that you can look in, but in reality, you do not care. If your design synthesizes and passes timing, then you can test it. Cheers, Dave
