NuvKFC
Contributor
4 years agoHow to disable SignalTap instance?
I have a "SignalTap.stp" file which contains many signaltap instances as follows picture which contain two signaltap instances.
I only want to disable the first signaltap instance.
Could...
- 4 years ago
No there should be checkboxes in the Instance Manager at the top. Maybe that's a Pro edition only feature because I have it. Try right-clicking an instance to see if there is an option to disable an instance that way.
RichardT_altera
4 years agoMay I know which Quartus version are you using? Quartus Standard also has the Enabled check box in the Instance Manager.
- NuvKFC4 years ago
Contributor
Hi RichardTanSY_In
tel Thank you, RichardTanSY_In
tel, very much. I'm using the "Quartus13.1 full version". Does it's too old? Thank you very much.
