How to disable SignalTap instance?
- 4 years ago
No there should be checkboxes in the Instance Manager at the top. Maybe that's a Pro edition only feature because I have it. Try right-clicking an instance to see if there is an option to disable an instance that way.
Disable as in remove the Signal Tap hardware for just instance 1 when you recompile the design? There's an "Enabled" checkbox in the Instance Manager in the .stp file to disable individual instances.
Hi sstrell
Thank you, sstrell, very much. Does the "Enabled" checkbox, you mean is as follows picture?
I think that it only can disable signals that users don't want to see in the Signaltap. Am I right?
Or it also can disable whole instance?
- sstrell4 years ago
- NuvKFC4 years ago
Contributor
Hi sstrell
Thank you, sstrell, very much. I can't find it. Maybe my tool's version is too old. Thank you very much.
