How to disable SignalTap instance?
- 4 years ago
No there should be checkboxes in the Instance Manager at the top. Maybe that's a Pro edition only feature because I have it. Try right-clicking an instance to see if there is an option to disable an instance that way.
Disable as in remove the Signal Tap hardware for just instance 1 when you recompile the design? There's an "Enabled" checkbox in the Instance Manager in the .stp file to disable individual instances.
- NuvKFC4 years ago
Contributor
Hi sstrell
Thank you, sstrell, very much. Does the "Enabled" checkbox, you mean is as follows picture?
I think that it only can disable signals that users don't want to see in the Signaltap. Am I right?
Or it also can disable whole instance?
- sstrell4 years ago
- NuvKFC4 years ago
Contributor
Hi sstrell
Thank you, sstrell, very much. I can't find it. Maybe my tool's version is too old. Thank you very much.
