JTurn
6 years agoHow to disable SDRAM ECC Check at bootup without manually editing the preloader source in 14.1 or later?
Hi All, I would like to disable the ECC check which occurs at the beginning of the Cyclone V boot process in order to save boot time. However, the only way I currently know how to do this is to edit...
EBERLAZARE_I_Intel
6 years agoHi there,
Is it possible for you to share the boot-log? Are you trying to disable the ECC?
EBERLAZARE_I_Intel
6 years agoHi,
If you want to disable ECC, you can disable it in Qsys/Platform Designer, then the preloader will also disable it.
If you want to enable ECC, BUT disable the ECC checking, I am unsure if this is possible using the BSP Editor to generate, you may need to generate your own custom preloader.
You may read the preloader customization information here, it's helpful:
https://rocketboards.org/foswiki/Documentation/PreloaderUbootCustomization131#Disabling_SDRAM_ECC
