10 years agoHow to develop a verilog model for a Peak detector with various constraints
Develop a Verilog Code for a Peak detector the following functions: Note: A threshold value is assigned to the sample ( noise barrier) Finds the Maximum peak from a sampl...
10 years ago --- Quote Start --- What do you want us to tell you, apart from the bad syntax of your code, which you could have discovered from trying to compile it. --- Quote End --- I am new to Verilog and i dont really know much about the syntax, I hoping for someone to help me clean up the code so i can use that as a basis to learn the verilog syntax. Thanks.
