10 years agoHow to develop a verilog model for a Peak detector with various constraints
Develop a Verilog Code for a Peak detector the following functions: Note: A threshold value is assigned to the sample ( noise barrier) Finds the Maximum peak from a sampl...
10 years agoWhat do you want us to tell you, apart from the bad syntax of your code, which you could have discovered from trying to compile it.
