10 years agoHow to debug the work item which global id is not 0? Using the emulator.
How to debug the work item which global id is not 0? Using the emulator. Using gdb to debug the host program and the kernels, I can break in the kernel code. But I can only debug the 0 work ite...
10 years agoI have solved my question.
When breaking at the work-item 0, continue running and it will break at the work-item 1. Because the Emulator implement actual serial execution instead of parallel execution.
