8 years agoHow to deal with the Out-of-Order Loop Iterations in single work-item kernel?
Hi, Today I tried to use single work-item kernel. I have a nested loop. In Loop Report, I found my outer loop not pipelined due to: loop iteration ordering: iterations may get out of o...
8 years agoYou can pipeline the loop like this:
__kernel void order( __global unsigned* restrict input,
__global unsigned* restrict output, int N ) {
unsigned sum=0;
for (unsigned i = 0; i < N; i++) {
for (unsigned j = 0; j < N; j++)
if (j < i) sum += input;
output = sum;
} However, since in this case both of the loops will run N times, depending on N, this code could actually be slower than the original case due to redundant computation. For such unpipelineable loops, it is actually preferred to use NDRange kernels.
