8 years agoHow to create a neg-edge Write pulse, from a pos-edge Write pulse?
I have a active-high signal that transitions on the positive edge of its clock when it has data ready to be written to memory. I also have ram memory (uses same clock) but expects the write ...
8 years ago --- Quote Start --- Can you post the code you have so far? It's a little tricky to visualize what you're doing. --- Quote End --- The goal is to write to the altera megafunction fifo (quartus 11), and I'm trying various ways to do the write request pulse, however the rdempty from the fifo never goes low (i.e. always empty). This screenshot : https://alteraforum.com/forum/attachment.php?attachmentid=14486&stc=1 was generated from this code :
wire cmd_push;
reg cmd_push_reg;
always @(negedge clk) begin
cmd_push_reg <= cmd_push;
end
​fifomf fifomf_inst (
.wrclk ( clk ),
.wrreq ( cmd_push_reg ),
.data ( 8'h5a ),
.rdempty ( tp1 )
​ I was thinking the clock edges and wrreq must be wrong.. or it's in reset.. but the megafunction code created by quartus doesn't expose reset so my guess that's probably not it
module fifomf (
data,
rdclk,
rdreq,
wrclk,
wrreq,
q,
rdempty);
input data;
input rdclk;
input rdreq;
input wrclk;
input wrreq;
output q;
output rdempty;
wire sub_wire0;
wire sub_wire1;
wire q = sub_wire0;
wire rdempty = sub_wire1;
dcfifo dcfifo_component (
.data (data),
.rdclk (rdclk),
.rdreq (rdreq),
.wrclk (wrclk),
.wrreq (wrreq),
.q (sub_wire0),
.rdempty (sub_wire1),
.aclr (),
.rdfull (),
.rdusedw (),
.wrempty (),
.wrfull (),
.wrusedw ());
defparam
dcfifo_component.intended_device_family = "Stratix III",
dcfifo_component.lpm_hint = "MAXIMIZE_SPEED=5,",
dcfifo_component.lpm_numwords = 1024,
dcfifo_component.lpm_showahead = "OFF",
dcfifo_component.lpm_type = "dcfifo",
dcfifo_component.lpm_width = 8,
dcfifo_component.lpm_widthu = 10,
dcfifo_component.overflow_checking = "ON",
dcfifo_component.rdsync_delaypipe = 5,
dcfifo_component.underflow_checking = "ON",
dcfifo_component.use_eab = "ON",
dcfifo_component.wrsync_delaypipe = 5;
endmodule
