16 years agoAfter long reseach, Quartus does not encourage do reduce the max fan out. However, we can set some setting in the QSF file to control it:
set_instance_assignment -name ADV_NETLIST_OPT_ALLOWED "ALWAYS ALLOW" -to set_instance_assignment -name MAX_FANOUT 500 -to set_instance_assignment -name IGNORE_MAX_FANOUT_ASSIGNMENTS OFF to set_instance_assignment -name MAX_FANOUT 500 -to set_instance_assignment -name ADV_NETLIST_OPT_ALLOWED "ALWAYS ALLOW" -to set_instance_assignment -name IGNORE_MAX_FANOUT_ASSIGNMENTS OFF -to set_instance_assignment -name ADV_NETLIST_OPT_ALLOWED "ALWAYS ALLOW" -to set_instance_assignment -name IGNORE_MAX_FANOUT_ASSIGNMENTS OFF -to set_global_assignment -name TIMEQUEST_MULTICORNER_ANALYSIS ON set_global_assignment -name TIMEQUEST_DO_CCPP_REMOVAL ON set_global_assignment -name PHYSICAL_SYNTHESIS_COMBO_LOGIC ON set_global_assignment -name PHYSICAL_SYNTHESIS_REGISTER_RETIMING ON set_global_assignment -name PHYSICAL_SYNTHESIS_REGISTER_DUPLICATION ON set_global_assignment -name PHYSICAL_SYNTHESIS_ASYNCHRONOUS_SIGNAL_PIPELINING ON set_instance_assignment -name MAX_FANOUT 500 -to set_instance_assignment -name ADV_NETLIST_OPT_ALLOWED "ALWAYS ALLOW" -to set_instance_assignment -name MAX_FANOUT 500 -to set_instance_assignment -name ADV_NETLIST_OPT_ALLOWED "ALWAYS ALLOW" -to set_instance_assignment -name AUTO_GLOBAL_REGISTER_CONTROLS ON -to
