16 years agoTo understand the Quartus behaviour with signal fanout, I set up a simple circuit with 8000 registers (simply connected as a shift register chain) and a reset synchronizer driving the asynchronous reset of each register.
With Cyclone III, Quartus used a global clock resource to connect the reset signal and had no problem to achieve 250 MHz clock rate.
