16 years agoHow to constrain output for SRAM in TimeQuest?
There are examples about source synchronous design such as SDRAM time constrain, but I wonder how to constrain output for SRAM in TimeQuest?
eg. no clock needed for SRAM, but you must point a clock in the Set Output/Input Delay setup. The SRAM data is changed with SRAM address latch in read process, but is it right to set the address as clock? Thanks very much!
