9 years agoHow to constrain HPS I2C Bus?
Hi My design uses a Cyclone 5 FPGA with an HPS that connects I2C Bus 1 SCL and SDA to external pins that connect to an RTC (Real Time Clock) chip with an I2C Bus interface. The HPS software can...
9 years ago --- Quote Start --- My main problem is the create_generated_clock statement. I've tried using create_generated_clock as follows: create_generated_clock -name rtc_scl -source [get_ports -nocase {soc_system:u0|soc_system_hps_0:hps_0|soc_system_hps_0_hps_io:hps_io|soc_system_hps_0_hps_io_border:border|i2c1_inst_i2c1_inst_scl[0]}] -divide_by 250 [get_ports rtc_scl] But it fails with these error messages: Ignored filter: soc_system:u0|soc_system_hps_0:hps_0|soc_system_hps_0_hps_io:hps_io|soc_system_hps_0_hps_io_border:border|i2c1_inst_i2c1_inst_SCL[0] could not be matched with a port Ignored create_generated_clock: Argument -source is an empty collection I wondered if anyone could advise me on how to fix the -source path in create_generated_clock please? --- Quote End --- Well, the problem is as it says ... the argument you provide to get_ports in the -source parameter is not a valid port (and probably should not be a port at all). It should be some internal reference clock signal, or maybe [get_ports {clock_50}] or something like that.
