13 years ago
How to constrain Async SRAM Interface
What is the proper way to constrain an asynchronous SRAM interface? I've already looked at the Async SRAM thread (http://alteraforum.org/forum/showthread.php?t=3423) so please don't point me there.
Below are the constraints that I've generated from the notes in the above link.
# Address (ADDR) trace delay from FPGA to SRAM
set tADDRtr_max 1.5
set tADDRtr_min 1.0
#  ADDR to DATA access time
set tAVQV_max 10.0
set tAVQV_min 10.0
#  Chip Enable (CE) trace delay from FPGA to SRAM
set tCEtr_max 1.5
set tCEtr_min 1.0
#  CE to DATA access time
set tCEQV_max 10.0
set tCEQV_min 10.0
#  Output Enable (OE) trace delay from FPGA to SRAM
set tOEtr_max 1.5
set tOEtr_min 1.0
#  OE to DATA access time
set tOEQV_max 6.5
set tOEQV_min 6.5
#  Data (DATA) trace delay from the FPGA to the SRAM
set tDATAtr_max 1.5
set tDATAtr_min 1.0
#  Constrain the read timing with respect to the address bus.
for {set i 0} {$i < 20} {incr i} {
   #  Create a clock on each output port of the address bus (addr)
    create_generated_clock -name "o_SRAM_Addr_bit${i}_clk"
            -source }]
for {set i 0} {$i < 16} {incr i} {
   #  Constrain the input timing with respect to each address bit.
    set_input_delay
            -max
            -clock "o_SRAM_Addr_bit${i}_clk"
            -add_delay
    set_input_delay
            -min
            -add_delay
#  Constrain the read timing with respect to the output enable (rd)
        -name {oe_clk}
        -source }]
set_input_delay
        -max
        -clock {oe_clk}
        -add_delay
set_input_delay
        -min
        -clock {oe_clk}
        -add_delay
#  Constrain the read timing with respect to the chip enable (ce)
        -name {ce_clk}
        -source }]
set_input_delay
        -max
        -clock {ce_clk}
        -add_delay
set_input_delay
        -min
        -clock {ce_clk}
        -add_delay
The clock source for the generated clocks (i.e. [get_pins {nes_pcb|clk_gen|pll_nes_sram_vid_CLKIN_50M_cyc4|altpll_component|auto_generated|pll1|clk[1]}]) is the same clock that is driving the o_SRAM_Addr/CS_n/OE_n signals. But I keep getting really weird warnings in Quartus when giving it the above constraints. I don't understand why it is saying there is no path between the clock source and o_SRAM_Addr/CS_n/OE_n when that same clock source is what is driving those o_SRAM_* outputs.
Warning (332088): No paths exist between clock target "o_SRAM_Addr" of clock "o_SRAM_Addr_bit0_clk" and its clock source.  Assuming zero source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit1_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit2_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit3_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit4_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit5_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit6_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit7_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit8_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit9_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit10_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit11_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit12_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit13_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit14_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit15_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit16_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit17_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit18_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_Addr"  of clock "o_SRAM_Addr_bit19_clk" and its clock source. Assuming zero  source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_OE_n" of  clock "oe_clk" and its clock source. Assuming zero source clock latency.
Warning (332088): No paths exist between clock target "o_SRAM_CS_n" of  clock "ce_clk" and its clock source. Assuming zero source clock  latency.
Is there a better way to constrain the interface? Treating every address line and CS and OE signal as a clock seems a bit kludgy to me. There must be a better way... But if not, how can I get rid of all those warnings?
Thanks!!
Jonathon
