11 years agoHow to constrain a standalone register
Hi All,
I am beginner to FPGA tools. I need to extract the area and delay for a register. module regr( input A, input CLR, input SET, input CLK, output reg Z ); always @(posedge CLK or negedge CLR or negedge SET) begin if (!CLR) Z <= 1'B0; else if (!SET) Z <= 1'B1; else Z <= (A); end endmodule As this register is part of a bigger project, I have set all input and output pins as virtual and set the CLK as Global clock. I am using a 4ns clock. Please let me know the way to constrain the input and outputs. Option A: create_clock -name clk -period 4.000 [get_ports CLK] set_input_delay -clock clk 0.2 [all_inputs] set_output_delay -clock clk 0.2 [all_outputs] Option B create_clock -name clk -period 4.000 [get_ports CLK] set_max_delay -from [all_inputs] -to [all_clocks] 3.800 set_max_delay -to [all_outputs] -from [all_clocks] 3.800 Please let me know if option A or option B is correct way of constraining. Regards, Upadyaya
