10 years agoHow to constrain a parallel bus from a PLL clock?
Hi. I have a couple of questions about the my design. Basically I have an FPGA which has a big data table which the values are readed and sent to an external DAC. The reading process and the DAC are ...
10 years agoHi,
My main question is about how to calculate the right phase needed in the attached diagram. I guess the phase required is equal to the path delay involved in the ROM logic. Also I am wondering if the source - synchronous compensation mode in the ALTPLL can help to avoid these offset.
