10 years agoHow to constrain a parallel bus from a PLL clock?
Hi. I have a couple of questions about the my design. Basically I have an FPGA which has a big data table which the values are readed and sent to an external DAC. The reading process and the DAC are ...
10 years agoHi Dirk,
Ok. It means calculate the multiplication in parallel to accelerate the procedure. But the ALT_MULT instantiation with zero latency is not a well implementation of a product operation? I mean if ALT_MULT uses a DSP multiplier it is not the best described hardware in terms of performance?
